Gene cafe e4 error
  • Gene cafe e4 error
    My gene cafe roaster is comming up with an e4 fault.
    It is turning but there is no heat.
    l guess it is the element or heat sensor,it is out of warranty so l will have to fix it my self .Has anyone done this operation before.
    cheers
    Re: Gene cafe e4 error
    Originally posted by 6E7B6C6C676B6C090 link=1300087751/0#0 date=1300087750
    cheers
    Where are you located ?
    See ya supplier for assistance, may be just the Fan OR Heater ?
    As it is dealing with High Voltages and you have to disassemble, it could well mean a Licensed persons. As such your supplier may or may not provide the part directly to you, as not defined as User Replaceable part.
    Then again who knows...
    Try the Sponsor / Supplier first.
      E4 is "Increase of the temperature in the temp. sensor 2 is detected" and = "Heater disconnection fan or sensor broken"
      Perhaps its this, though give them a call first.
        Thanks for the link l saw that a pity they dont show a picture.
          Just use the Google search and all is  reviled 120V version.
            Below is a pic of my heater.
            Its not too difficult to replace. There are two good sets of instructions on the web, one at avacuppa, and another at the coffeetime wiki. I used both.
            If there is no heat, then it is pretty likely to be the heater ... But contact avacuppa before buying it, they are very helpful.
              Thanks for that l ended up finding that one on avacuppa.
