Originally posted by DesigningByCoffee
View Post
I had exactly the same thought about the steak literally 2 days ago. I am not using a data logger, my heat gun is 2000W with 2 settings.
My uncovered roasts, the gun had to be on the high setting and to my mind and taste it was sealing the outside of the bean prior to any heat getting inside the bean. Results where always brighter / lighter flavours which worked well for filter AP and cold brewing. However even going into second crack i was not pleased with the espresso shots, not much depth to the flavour, blonding quickly.
Now i am just using an old small pizza tray with a rock on it, to mostly cover the BM. The circle leaves a spot for the heat gun nozzle and another small opening on the pother side where steam / smoke / chaff escapes.
I can now run on the low heat setting for 7mins, gives a really nice even look early on and i can see / smell there is more heat getting into the beans. I then move the tray to about half covering and switch to full heat which gives me rolling FC around 10.30.
I then drop the HG back to low and cover up BM again and cruise for 3min, switch back to high and take the cover off altogether which results in start of SC around 1.30 later.
Results for espresso are just so much better i am very happy and so are my family (i am now roasting for them)
Deeper richer red / brown colour, loads of crema and the shot does not blonde nearly as quickly.
Flavours are much stronger and smoother and lasting = i can taste my coffee long after i have finished it.
Definitely am an advocate for covering the coretto!
