KK, thank you for the diagram of the shaft and nice picture of the shaft from different angle
I just havent made my decision yet.....
I was going to do all DIY, but couldnt think how to make agitator, connect to shaft and then to motor.
I knew Eds version KKTO seem to be quite good too.
Will update when i can source a motor that could rotate around 50-80rpm and enough torque( i found one motor that has 17kg cm,80rpm,12V!) with correct components.
Im aiming for over 800g average in a batch
So need to find my way to make a gear box or reduction motor by myself and then somehow connect with the shaft...
