Re: RK Drum - 4lb (2 kilo)
Alan,
Yep. Very happy with the drum.
I can do 2kg of green, but my standard roast is 1875g of green as it results in a little over 1500g roasted which then goes into 6 x 250g bags.
I think the combo kits look good but the motor is a 110v and not applicable to me in AU. Where are you?
I measure air temp at this stage. To come up with a bean mass option would require some engineering above my pay grade at this point. Im sure it could be done, but I think you might need to do a mod which involved some bearings at one end of the drum. Anyhow, Im happy with my method at present.
I dealt with Shane from RK drums and he was exceptionally helpful and friendly along the way. He got freight estimates and was very fast responding to e-mails, so if you are unsure, I would suggest just dropping them a line and starting a conversation. One thing I would suggest if you do decide to purchase, is to ask if you could at least purchase the rotisserie rod setup from them. I have not found a perfect fit rod as yet. The one i use is probably 1 or 2 mm smaller than optimum. Probably because we use metric and US does not.
Hope that helps.
Brett.
Alan,
Hope that helps.
Brett.
