Re: RK Drum - 4lb (2 kilo)
Alan,
You could consider the 6lb drum if it was really important. The drum diameter is the same, the length is greater I believe.
The amount I roast is always in 625g increments (yielding ~500g roasted). I also usually get 5kg minimum of any bean.
The theory is that I should always have 625 or 1250g left in a bag and can either do smaller roasts or blends with it.
Not sure that messing about with a voltage converter is worth the drama personally, but thats up to you.
If youd like to drop over one day and see the drum in action, drop me a PM.
Brett.
Brett,
Thanks for reply.
I was hoping to roast a similar amount of beans (1.5 - 2.5), but 2.5 kgs would be a good option as Andys bags are that size.
I am also in Melbourne. I have wondered about the complete kit vs price to source things locally, but have not done any sourcing. I think voltage converters for 240 to 110 volt are reasonably cheap.
I am used to monitoring bean temp, as I currently use a coretto. Sounds like you have been doing OK with air temp only.
Thanks for the tip on rotisserie shaft.
Alan
Alan,
Yep. Very happy with the drum.
I can do 2kg of green, but my standard roast is 1875g of green as it results in a little over 1500g roasted which then goes into 6 x 250g bags.
I think the combo kits look good but the motor is a 110v and not applicable to me in AU. Where are you?
I measure air temp at this stage. To come up with a bean mass option would require some engineering above my pay grade at this point. Im sure it could be done, but I think you might need to do a mod which involved some bearings at one end of the drum. Anyhow, Im happy with my method at present.
I dealt with Shane from RK drums and he was exceptionally helpful and friendly along the way. He got freight estimates and was very fast responding to e-mails, so if you are unsure, I would suggest just dropping them a line and starting a conversation. One thing I would suggest if you do decide to purchase, is to ask if you could at least purchase the rotisserie rod setup from them. I have not found a perfect fit rod as yet. The one i use is probably 1 or 2 mm smaller than optimum. Probably because we use metric and US does not.
Hope that helps.
Brett.
Hi Brett,
I am considering the RK 4lb drum.
Are you still happy with the drum and have you been able to do a 2kg roast sucessfully?
Did you think about the combo kits RK offer?
Do you measure bean mass temperature, or only the air temp in BBQ?
Alan
Thanks for the feedback that saves messing around trying different options
I have 4 straight ones in both drums. The RK is built so there are no places for the beans to get caught. All roasts thus far have emptied out clean. Very impressed by that. The older drum did hang on to a small number and needed a clean out every now and then. As for a motor, yes the windscreen wiper motor runs at a far higher RPM than the BBQ rotisserie motors. I believ mine is from a Ford Escort and just needs 12V power and I am good. I have heard of others getting a motor for the back wiper and it oscillates rather than spins one continuous way, so you certainly dont want one of them.
Hi Brett I would be interested in your thoughts on how many paddles you would consider optimum. I am wondering if 2 paddles running along the length of the drum opposite each other would be enough or if 3 or 4 evenly spaced around the drum would mix the beans better. Maybe the Behmor sytle paddles would offer better mixing? It is a bit hard to judge without any previous experience with this type of drum or BBQ roasting. It seems from the photos that RK seem to have four in the 6lb drum but I cannot see any indication of how many in the 4lbOriginally posted by 626570666B7D5B353D3D3D040 link=1323495861/8#8 date=1329289656It would need to have something added to deflect/agitate the beans during roasting.
I tried a small qty of Yemen Mocha Ismaili and Ethiopian Harrar Longberry beans which are the smallest I had and they did not fall through the holes. I was told the hole size and if my memory is correct the holes are 4.2mm +/- Broken beans may be a different story.Originally posted by 61667365687E58363E3E3E070 link=1323495861/8#8 date=1329289656Id also want to measure the holes. They look quite large to me.
In reading previous posts it seems wiper motors are used to drive the drum, do they tend to run at a suitable rpm or do they need a gear box ? BBQ motors appear to be too slow
If you start with a drum without vanes/agitator, Ive always fancied the idea of making up a removable bracket or brackets to fit internally and mount the vanes on bracket rather than modify the drum itself. Something like square cage inside a round one.
Working on a flat, square or box bracket on a workbench would probably be easier than working on the inside of a drum intended to roll and rotate, and definitely easier to modify vane shape, size and position.
Ive always liked the idea of reversable mods.
I totally agree and noted that in my comments below but it would be very easy to mount something internally & no drilling required other than in the paddles which is good as drilling stainless can be an issue. The holes seem OK, maybe smaller beans need to be checked, I think the majority of the beans I have used would be okOriginally posted by 686F7A6C6177513F3737370E0 link=1323495861/8#8 date=1329289656It would need to have something added to deflect/agitate the beans during roasting.
At $82 it is worth having a play
Trentski indicates it is ok to post the link so here we go.
http://www.auspit.com/index.php?act=viewCat&catId=2
In the the larger drum it would be harder to control the temperature as it is longer but I guess it depends on the set up you have, the shorter one looks better suited. The instructions advise not to go over 8.8Kg on the spitbar!!!! Clearly not the coffee rating
The Spitmount Kit would be a quick mounting solution but I guess changing the motor would be necessary to optimise the rotation speed
Anyway I thought it would be of interest to a few people, I might need to grab one and have a play !
It doesnt look like it has anything on the inside of the drum.
Certainly worth a look though. How much was it selling for?
Brett.
The link should be OK as they dont compete with any of the sponsors, the BBQ in the pic is just for show, the ring sitting on the BBQ and motor etc is whats for sale
http://www.joesbbqs.com.au/weber-charcoal-kettle-rotisserie-p-1307.html
The adaptor ring sounds interesting but I cannot find them on the web site maybe the range has been dropped ?Originally posted by 646162626C6572000 link=1323495861/5#5 date=1329283001adaptor rings for kettle BBQs
The drum looks like a good entry to BBQ style roasting. They also have a motor and mounting shaft available for the drum. Easy mods would be "Paddles" internally to move the beans around and a handle on the removable end but that should be quite easy to do
Originally posted by 417E676E7854590B0 link=1323495861/4#4 date=1329278267Stumpled on this today, it is aimed at the BBQ & camping market. It does not have a hinged side plate like the RK to release the beans but it is lower cost and Australian made. Some simple mods could be made to adapt it as required. It is made of stainless and the hole size looks to be acceptable for most beans
When I was shopping for a new BBQ last year I also found this product. Because, well, everyone like to accessorize dont they !? I recalled it when this thread started but couldnt find it again because I didnt purchase for various reasons.
Whats more interesting to home roasters, is this company also sell adaptor rings for kettle BBQs that increase the internal volume substantially as well as providing mounts for the rotisserie.
Approx. US$80Originally posted by 486C76666D64050 link=1323495861/1#1 date=1323585780nice! how much was shipping?
