Little issue with my Gene Cafe: need advice how to fix it
  • Little issue with my Gene Cafe: need advice how to fix it
    The little problem is - in the glass drum, on the opening door, the grid which is separating beans from chaff collector has come off (see picture).
    Anyone had this problem with their Gene Cafe? I suspect soldering iron is of no use, because I think tin will not hold at the roasting temperatures... Drill little holes and put screws? I am not sure... what else?
    Id hate to replace the entire glass drum because of this pissy little grid, but I cant roast without it...
    Re: Little issue with my Gene Cafe: need advice how to fix it
    Hi chartres,
    I cant help with a gene-specific answer because I dont own one. But solders are available for higher temps than your gene can produce. Look for hard solder or silver solder (it has other names too but I cant recall right now). Im sure google will clarify.
    The bigger issue might be owning an iron that reach the temp necessary for brazing/soldering metal to metal.
    I dont think the fluxes and metals or alloys used in solders would be an issue once cleaned but you might need to check that too.
    d.
      I used a high temperature silicon sealant for a ptu ignition module to seal up a plastic join on it- this was mounted to the front of the engine - is called Silastic. Dont know if this would be effective for the roaster.
        Why dont you send an email to Avacuppa (click sponsor link <--------). He may be able to offer a simple solution as he sells the Gene.
          Maybe you can use a paperclip, bend it into a bracket to hold the grille in place?
            ok, I have drilled a couple of 2mm holes and put a couple of self tapping screws for sheet metal
            it fixed the issue for the moment...
            thanks for replies
              Agreed, certainly would have done this prior to drilling any holes
                well, naturally I did send email prior...
                basically its replaceable for 40$ plus postage..
                or its fixable by selftapping screws for under 1$...
                for the moment its fine and roasting well ;-)
                  My Gene Cafe has done the same. It's 6 years old and has probably roasted about 50kg of coffee in that time. (I go through phases depending on employment and living arrangement).
                  I think Ill do the screw trick too.
