Originally posted by bennett
View Post
Behmor and my stupidity
After every 5 roasts max. I use the original green colored Simple Green sprayed onto a cloth and wipe the Behmor clean before doing a dry roast.Originally posted by Andy View PostSimple green works well but I don't like the smell much.
I prefer using the orange oil based cleaners.
The dry roast seems to get rid of any residual toilet candy smell left by the Simple Green.
Simple Green also makes a non-toxic Microwave/Oven cleanerin a spray can. I guess this is more concentrated for heavier build-up.
Wonder if this is OK for the Behmor?Last edited by CafeLotta; 23 October 2012, 09:29 PM.
I'd avoid using CLR to clean your Behmor. CLR contains acids (Calcium Lime Rust, more commonly known as CLR, is a household cleaning product used for dissolving stains, such as calcium, lime, and iron oxide deposits. Its ingredients include water, lactic acid, gluconic acid, lauramine oxide, and Propylene Glycol n-Butyl Ether.) Use Orange Oil (mild detergent) as recommended. Easy to get at Woolworths. Do not use acids on metal, especially when you're going to heat the metal quite hot!!!! Your Behmor will disappear!Originally posted by DavidW1960 View PostAny thoughts on using CLR?
