I havent figured out the coding for facebook yet, so with your indulgence I will just post the link here. Coffee roasting in a breadmaker - YouTube
In the early days of using a breadmaker for roasting, I would roast with the gun just firing into the open basket. Works absolutely fine but the heat reflection would melt the gun. After wearing out breadmakers and guns, I made a quick lid as seen in the video, and inserted the gun nozzle in tightly so its more or less fixed to the lid. I get no more heat reflection and no more melting of the guns.
This particular setup is in Wales U.K. and is used all year round regardless of weather. I say regardless, when I meant to say even though its cold most of the time.
Ive roasted in the rain, in snow and occasionally in brilliant sunshine. As you can see I have an external thermometer which is also occasionally attached to computer software for profiling, but now I know this particular setup quite well, I can work from temperature and from colour and smell of the beans Im familiar with. My usual roast volume is 500-650 grams at a time and takes from 13-16 mins to completion at either just before or just into 2nd crack with a 3-minute rest between 1st crack and to the end of cycle.The need for further insulation on this machine has so far not been a necessity. I control the rate of heat by either full power or by the lower setting to try and average 7-10 degrees rise a minute. I believe the gun is a 2kilowatt output on high. I always pre heat the first roast of the day to about 250C and then dump the beans in. The first 4 minutes I use as a drying time on low heat as the temp drop is to about 70 or 85C and then rise it through the profiles Ive established for each varietal. Further roasts are not preheated as the basket is warm enough.
This machine is used for my personal consumption when in the UK, and for testing beans, cupping and discussing profiles for the Toper. The smaller amounts allow for this, plus of late I have been roasting some torrefacto and have some really good results from it.
I dont think I have found a better small roaster up to present than using air guns and the breadmaker. In saying that, I have recently stripped one and direct powered the motor, and will be changing the basket out for a larger pan. Stripping the breadmaker - YouTube
This particular breadmaker has been in use for over a year making about 2 kilos a week.
