I am trying to connect another thermometre sensor to my roaster which as a PID. The external one is able to connect to my computer.
The problem i have when i conenct them is that i am getting slightly different about 1 - 5 degrees different readings. The delta movements are also not the same either between the reading (Roaster PID and the external sensor).
I have ensured that i have connected the correct +/- to the right wire. What else could be causing this issue?
Many thanks in advance,
Mike
Mike
