After doing the popper thing over winter I decided I was going to have to upgrade after the first warm day took my roasts sub-5 min. The major criteria I set for my roaster were: ability to directly see and hear the progress (similar to the popper), mostly conductive heat transfer, optimal mixing, total control of the process, a 250gr minimum batch size and obviously cost. As none of the roasters within my budget really promised to deliver all the above, the Baby doesn't allow direct visualisation and the Diedrich IR1 is on the wish list for when I win the lottery, I decided I'd have a go at building one to spec. I've managed to cobble together a drum roaster that has exceeded all my expectations, but now the inevitable upgraditis has set in and I want to install a thermocouple!
I would prefer a bean mass probe, but I suspect it would get knocked around, as you can see from the first action pic there's a lot of bean movement - so will probably settle for an airtemp probe. The major issue is positioning of the probe and the heat tolerance of the lead - I suspect even the stainless braid may take a beating from being this close to the heat source. Any advice would be gratefully received, just keep it simple - there's a good reason this thing runs on a cordless drill!
I hope the images upload successfully - not much use if I rabbit on about the thing and no-one can see what I'm on about.
Dave
Dave
