Hottop wont power up
  • Hottop wont power up
    Hey crew, I have here a hottop which wont turn on. I've checked the hottup usa site for troubleshoot/repair guides and:
    checked with multimeter the element/fuseloop, OK (80ohm), chaff tray switch, ok. 240V at mainboard, yes.
    When I plug it in, nothing at all is happening...
    scratching my head now...
    You may have seen this already ?
    Hottop Coffee Roaster Troubleshooting Guide
    Mentions a fuse on main board as well as fusible link. You mention you have checked the fusible loop but no mention of the fuse?
      more diag... it seems one of the resistors on the mainboard became a little toasted. I replaced it with some help identifying the values from the au hottop distributor, but even with the replaced resistor, it's a no go. Makes sense, as a resistor that has failed usually means something else will fail along the way also.
      Probably going to have to look at a new mainboard :/
