So I haven't seen a post on this yet but here is a new roaster coming out hopefully this year!
Currently in late prototyping stages it is shaping up nicely and specs are as follows:
1kg batch size
ET and BT measuring
front display with the 2 temp readings, can also display RoR and other important stuff
US 120v and 240v models
1550w power which when combined with the high efficiency of the design can translate to sufficient power for the batch size
USB ports and potential to share profiles and the like in the future.
Computer controlled roasting
Manual / Automatic control
10 Power levels
10 Fan speed levels
Variable Drum speed
External cooling tray
USB: Computer logging / control
Compensation to control input power fluctuations.
Roast cycles: no limit
5.6L Steel Drum
Fully insulated
Quiet operation
Easy cleaning
Length (without Cooling tray): 560mm
Width: (Legs) 320mm
Height: (without funnel): 390mm
Weight: TBC
There is a tonne of info on the homeroasters.org site and they even have the creator of it on there answering questions. There is a possibility of a tour through EU, USA and Aus this year.
Looks a beauty and priced between a hottop and the cheap chinese 1kgs. ~2k?
Marcism
1kg batch size
ET and BT measuring
10 Power levels
10 Fan speed levels
Variable Drum speed
5.6L Steel Drum
Fully insulated
Quiet operation
Easy cleaning
Width: (Legs) 320mm
Weight: TBC
Marcism
