Originally posted by trains
View Post
6 screws (no torx/hex) on the end closest the control panel. 3 underneath & 3 top edge.
7 screws on the other end - same 6 as above but one extra where it wraps around inside the edge of the door. Open the door and you will see it about half way up. This screw has a flat head so keep it separate.
8 screws + a tab to unbend to remove the top*. 4 screws top back, 4 under top edge of the door opening (also flat head but silver so easily identifiable).
* The top has 2 tabs that slot into the top of the control panel. On mine the one of these closest to the end had been bent up. This had to be bent straight to allow the top to slide forward for removal.
5 (or maybe 6) screws holding the control panel in, but all except the bottom one furthest in are relatively easy to access (magnetised screw driver is helpful for these).
The end panels slide forward for removal. Don't get too gung ho with the one on the control panel end as the fan cable runs from it to the circuit board. There was a zip tie keeping some cables tidy that I had to cut to be able to remove the light cable after unplugging it.
All done and it actually still works
