So, after a failed attempt to boost the capacity of my popper by wiring a seond fan in series and adding a central cone to the chamber for spouting (see the RHS), I decided I need more air!
Enter an 800W motor from a hand held vacuum cleaner, some PVC fittings, a custom built pine enclosure, and a heap of mica insulation sheets, and voila (see LHS)
This baby will easily move as many beans as will fit in the chamber before it overflows (ca. 200g), even when green and without the heat on!! I've fitted it with my osPID, measuring the roast chamber inlet air temperature with a bead k-type thermocouple.
This prototype is not 100% finished, but close enough to use in anger. The final version will probably feature a conical roasting chamber (for spouting) with a glass top, a ceramic tube to contain a higher power heating element, and some other features.
Hoping the popper element will put out enough heat, otherwise it's back to the workshop!
Itching to do a roast.
Only drawback is I've just finished it, it's 7:30pm, and its a bit noisy.
