My "roaster" might give some of you a bit of a laugh. I had read up on using the old popcorn machine for roasting and was about to head out to pick one up, when my engineering brain slapped me and set me the challenge of building something workable using what I had lying around. (Could have also been the wife's voice in my head asking why I needed to buy more coffee related equipment after buying the new Lelit, eazytamp, etc etc...)So I gathered up some bits and pieces and put together a small 'cement mixer' style barrel driven by a cordless drill, with heat provided by an XU1 hot air gun. The barrel was an old Ikea tin; I find the design on the sides of the tin really helps bring out the floral notes in my roasts.
I installed some simple mixing paddles/strips up the sides of the barrel to help agitate things. Basically I hold the drill in a bench clamp angled at about 20 degrees backwards, use another clamp to get the drill rotating slowly, then hand hold the hot air gun at the opening (moving closer or further to regulate temperature). I set the hot air gun to it's lowest heat setting which from the spec sheet is apparently 300 degrees celsius, and I assume about 1000 watts. I have played around with holding the gun closer and further away and by doing so have reached first crack as early as 8 minutes and late as 13 minutes. I also have an IR thermometer which I have played around with during the roast however as yet have not had a huge amount of success with repeatable/useful readings, which I imagine is a lot due to variations in emissivity of the beans as they go through the roast cycle. I have been roasting 200 gram batches with relative success (not that I have anything to compare to!). Have done 8 roasts so far, the photo attached is from the very first roast. The results seem to be fairly even in roast colour, although there is some variation due to bean size.
Was quite a fun little project, and the end result is far better than I could have expected! Further modifications to come of course...
