Hi All,
One of the Blade Springs (split ring that holds the chaff blade in place) in my Gene Cafe has broken, I have contacted Avacuppa and its not a spare they carry and I have been unable to locate it as a replacement part.
The existing rings are 3 loops, the closest I can come up with appears to be 4mm stainless steel split rings (2 loops)that are used for fishing.
Given that a replacement will need to withstand roasting temperatures, would these do? would the heat have any effect other than making them brittle? They come in packs of 100 so it wouldn't matter if they don't last more than a few roasts.
Has anyone had the same issue and come up with a different solution?
Caryn
Caryn
