Can anyone suggest what to do. I cleaned the drum today after roasting, and the lid fell off. The little metal wire that was holding it in place just got detached. I have no idea what to do. I am guessing it can be soldered or welded on if soldering is not appropriate but wanted to check here first before doing anything stupid and destroying it completely. I have no idea where to get the replacement if needed. Bought my Behmor here about 1.5year ago.
Behmor Drum Lid Broken
G'day jabbba...
You know those very small stainless steel chains that you sometimes see in pet stores and the like; don't see why you couldn't grab one of these, open and remove a couple of links and then position them appropriately as hinge points back on the drum and re-close. Have done this sort of thing many times on small devices and works a treat...
Originally posted by @3aan View Post...and yes the are nickel plated "so what" ??
Java "Prefers to listen to heavy metal rather than drinking it" phileToys! I must have new toys!!!
Originally posted by Javaphile View PostMany (Maybe even most?) chrome platings are not food safe. Additionally; cheap platings commonly delaminate/flake off both when the part has been bent or when the part is subjected to high heat. Combine those two and the chances are even higher that delamination/flaking will occur.
But only for You I made a pair of others (the rings where to loose) see the picture for some detail. Stainless steel.
