N.B. This is a design entirely developed by Koffee_Kosmo, merely partially implemented by me.
With much thanks for help from KK and prompting from nikko, here's a new thread for my new KKTO build I've been putting together.
As my frankenpopper has been a fun experiment, but no where near consistent enough for my needs - the KKTO was a necessity for keeping up the newly formed home coffee habit!
I managed to score the correct pot set (Metal handled Arcosteel) on scumtree for $30 and so it all started.
KK sent me a purpose-manufactured motor, drive shaft and washers, agitator materials, insulation and false floor.
I purchased from fleabay some hi-temp hosing, a DMD and thermocouple.
Still to get is the TO itself (hopefully it'll come back into ALDI, otherwise I'll get a Kmart one, they're the same), a power 12v 2.5A power supply for the motor, a silicone gasket maker, and materials for the pot platform.
What follows are some pictures of the build so far.
This is the pot set recommended for a 'standard build':
This is the fitted silicone. Note that the top tube (green) has been split carefully down the middle to sit over the lip. The bottom tubing has been attached with a 2mm tube connector from Bunnings (I had to trim the connector down to make it sit flush against the pot as it's square). It sits above the small lip, and will fill the gap made between the two pots when they're put together.
This is a photo of the black tube filling the gap between the pots. I will later use some silicone gasket maker to hold it firmly in position.
I had to drill my own pots, so I used the following method to find the centre, as I wasn't willing to trust the rings on the pot itself. Note the lines drawn to intersect the pot edge at two points. I then found the centre of this line and drew a perpendicular line across and through the centre of the pot. I did this 3 times and approximated the meeting point. It was very slightly different to the lines already on the pot.
This is the resulting drilled hole. 18mm in diameter, which is good as the hole ended up having drifted 1mm off centre once we'd finished.
The insert was also drilled at 14mm, but we just had to go with the already present drainage holes as our drilling guide.
More to come...
More to come...
