After reading through dozens of posts I'm still unsure about the max temps I should be expecting in my Behmor 1600 plus. I've happily done over 100 roasts over the past few years, with (usually) great results, at least to my taste.
But having recently added HeatSnob unit and using the new features of the Behmor plus panel (A and B temps), I'm wondering if I could be doing things better. I know that the results in the cup are much important than a roast graph but it has me wondering...
In particular, I always seem to be hitting 1C at around the 145C mark. From that point ETs don't rise much at all and 2C is usually at the same or only 1 or 2 degrees higher. This has been consistent on over more than 20 roasts of Ethiopian Gambella using a 400 g load on P3, D settings. I tend to preheat to around 100 C before loading.
I've noticed lots of roasters in the forums using Behmors reporting steep temp rises to over 200C.
There is no way that my Behmor will reach 200C unless I am missing some trick. The few times that I have tried a faster temp rise with a P1 manual setting it has auto shutdown to cooling cycle at around 170C.
I'm also interested in those steep temp drops that people post on cooling, with temps dropping from 200C to 20C in a minute or 2. In my Behmor, with cooling cycle and door open, it takes the full 13 minutes of cooling for the temp to go from 140 back to 25 C or thereabouts.
The temp logs are a great but for me they are raising more questions than answers. Perhaps I can get some here.
Thanks,
StevenC
Thanks,
StevenC
