I searched on the interpretation of the results for the system self test without luck and am posting my findings so far.
To perform self test: Unplug roaster, press and hold START, plug in roaster, release start.
Here are the results of mine.
r3.29 Software version
230 Voltage selection
0000 Main heating element
1111 ?
2222 Draw fan (top of roaster - afterburner circuit)
3333 Internal light
4444 Scroll fan (rear of roaster - internal roast chamber air flow)
5555 High speed drum motor
6666 Low speed drum motor
7777 PC fans side and rear
8888 ?
9999 ?
054C A or B temp
blank
054C A or B temp
The above repeats itself again.
I noticed the after burner element doesn't get triggered during the self test (confirmed working ok otherwise).
Couldn't figure out what (if anything?) was triggered in steps 1, 8 and 9 and if the blank is deliberate between the 2 temp readings as they would generally be the same unless the roaster is hot (presumably this is the case).
1111 ?
3333 Internal light
8888 ?
9999 ?
054C A or B temp
blank
054C A or B temp
