Indoor roasting: yes Computer profiling possible: Yes (Assess for BT & ET Probes) Chaff removal chamber: Yes Smoke exhaust: Yes Gas auto ignition: Yes Tryer: Yes Roast Window: Yes Roasting capacity: 50g to 600g Roasting time: 6 - 20 minutes Roaster size: 530mm x 300mm x 547mm Heat control: Complete low to high temp control Flame diffuser: Yes - choice to have direct flame on drum or not Heating source: Infra-red ceramic burner Gas type: LPG propane / butane Gas consumption: 0.18kg/h Voltage: 12V - 3.6A Power 43.2W (power supply included) Roaster Gross Weight: 14kg Analogue thermometer: °C (350) and °F (650) Bt & Et probe access for data logger & artisan profiling Drum material: Special cast metal Drum Motor: 2 Speed - 45rpm & 60rpm Air flow control: 2x 12volt fans @ 170cfm
They hand build the roasters in the UK. I have a direct email to contact Johan. Is gas not allowed in Australian roasters?
Absolutely allowed. The overwhelming majority of our commercial roasters are gas fired.
I'm pretty sure that what Chris is referring to is if the roasters are imported with a gas train already fitted then they would have to comply with Australian Standard specs.
Compliance testing is a lengthy, involved and costly process which may result in the need for an Australian specific model or the supply to an Australian importer without
any gas and or electric components. The importer would then fit the necessary components here, to meet Australian standards. Either way would add AUD$$$ to the retail price.
Ahh, regulations...
But speaking of price, the price in Denmark was about 2200 australian $. Thats pretty good!
Yes, but if that's just a straight currency exchange value it won't take into account shipping, import duty, compliance costs and whatever other costs are involved.
That price was including shipping og the duty/taxes within EU countries. Not sure about the rules from UK to Australia, but is there some sort of commonwealth tax/duty?
