Morning all.
Have been thinking a bit about the temperature probe and why it seemed that my FC/SC temps were well above what is the accepted standard for arabica beans at 196 deg C.
There is three different aspects that I think will be affecting why my reading is significantly above 196:
1. I missed the very start of FC and where I registered FC was actually some degrees cooler, but couldn't hear the first snaps and the temperature kept rising
2. The temp probe isn't truly reflecting the bean temp but a hybrid of the bean temp and air temp
3. The calibration is a bit out on the temp probe
I think all 3 are partly true to some extent, but 1 & 2 are hard to verify - so I decided to do and experiment to verify #3.
I boiled a pot of water and kept it at a rolling boil on the stove and inserted the temp probe. I then let it sit in the water for a good 10 mins making sure the probe didn't touch the bottom, only the water itself.
Results - well it was pretty clear. The probe registered 103.8 (there was a little movement back and forth). Given water boils at 100 degrees C at sea level and I'm only 150M from the beach I'd think the calibration is indeed out a little at 100 degrees C, perhaps 3-4 degrees C.
What this means for my roast:
I recorded FC at around 204 Degrees C (from memory, but should check my actual log!) - so even taking this into account I'm still 4 degrees or so out. Which means more than likely I missed the start of FC and the temp probe doesn't 100% reflect bean temperature, but both bean and air temperature.
