ECM Elektronika Profi II Espresso Machine - With Genuine Line Pressure Pre-Infusion
  • SOLD ECM Elektronika Profi II Espresso Machine - With Genuine Line Pressure Pre-Infusion
    The machine is about two and a half years old and is in perfect working order. Meticulously maintained and serviced. Only a very few minor signs of use. It has just had a tank and line descale, E61 head de-scale and lubrication, back-flush and new group head gasket. The machine was plumbed in fed with only 4 Bar, 0.5 micron carbon-filtered water since new. I had a unique pre-infusion (line pressure) / wetting (tank) function added. This provides the best of both worlds with genuine variable pre-infusion (line pressure) as well as precise volumetric shot dosing through the push-buttons (see photos).
    The package includes standard single and double ECM portafilters and blanking plate as well as a genuine ECM matching naked portafilter for visible viscous pours and shot channelling detection.
    Machine Features:
    Equipped with a super-quiet rotary pump
    Switchable from 3-litre removable water tank to direct plumb-line water connection
    Drip tray can be drained out
    2.1 litre stainless steel insulated boiler with heat exchanger
    Elegant high-grade feet
    Individually programmable dosing (precise volumetric control) and manual dosing through the control button panel. Doses stay constant with grind variations.
    Automatic back-flushing/cleaning program through the control panel
    Comfortable quick steam and quick water lever wand valves
    Insulated steam arm - no finger burns!
    Low-noise performance through sound-insulated body
    Water tank with float level detection for automatic shut-off in case of tank low water
    Big drip tray and allowance for big cups
    Ergonomic chromed filter holder for perfectly weight-balanced handling
    Dimension: 355mm (W) x 430mm (D) x 393mm (H)
    Net weight: 23.5kg
    The machine is packed and secured in the original carton and packaging. Suit new buyer. I'm happy to arrange a courier to anywhere in Australia at the buyer's additional cost, or local pick-up. Price $2500
    Hi Mikef Where about in Australia are you??
      Whoops. I will include that. I live in Melbourne. cheers Mike
        Reducing the asking price to $2,200. As-new machine with ECM naked portafilter (cost $3650 and $150 new). Machine location is Beaumaris, Melbourne, 3193.
          Hi Mike, I'm interested if you can send me a PM to discuss? I can't send one as a new user.
            Hi Mikef, interested in this machine. If you could send me a PM, I'd love to discuss local pick up - I'm located in Melbourne too. Thanks!
              The machine is SOLD.
