Hi there,
I will probably regret doing this, but I am putting my ACS Vesuvius Pressure Profiling machine up for sale. Asking $3500.
It's a beast of a machine, well ahead of its time. The Vesuvius is a pressure profiling, dual boiler machine that offers unparalleled control to the home barista through multi-phase profiling, stainless steel boilers, a FG304 Gear pump and a dot matrix touch screen control.
The gear pump has a speed controllable motor that allows you to adjust brew pressure to program and save five different profiles. The profiles have seven phases each that allows you to set a pressure between 2 and 12 bar and adjusted in 0.2 bar increments. I have a Turbo shot, lever style & flat 9 bar profiles I regularly use. You can try long pre infusions and more, it's been a great machine to try out many styles that are talked about on the internet.
This machine will fit under most standard cabinets and a 3L water reservoir that actually pulls out of the left side of the machine. This means you don't need to move the machine or cups when you need to refill it. You can also plumb the machine directly to your water mains, this water is pumped into the water reservoir instead of the brew boiler so your line pressure won't impact your brew pressure.
It can be programmed up to two unique on and off times per day. There are also a number of energy saving options that can be selected to reduce the heat of one of both of the boilers after a set period of inactivity. Comes with a spares box of bits, instruction manual and I think I still have the shipping box aswell. Located in Canberra and would prefer a local sale so the machine can be viewed, but shipping can be an option.
Always fed filtered soft water, cleaned and maintained regularly. Please pm for any further info.
