Presents as nearly new. Made in Italy, not being used anymore as I’ve moved to a single doser setup. Currently going for around $1200 on most sites.
The electronic panel can be programmed for two separate doses, each timed for 1-99 seconds, ideal for both single and double shots. Also has a manual grind out when you just need that extra little bit.
I have done around 4200 ‘shots’ I do a double each time (20g grind) so I’ve done around 2000 uses of it. Which when you think about it, a normal café is doing 200-300 cups a day so it had done only 2-3 weeks worth of work. I cleaned out with Caffetto cleaner every few months.
It weighs about 10Kg and is built like a tank. I think I have the box still will need to check storage.
Mazzer Mini Electronic A Grinder Features
64mm Flat Burrs — Grinds for espresso with precision, consistency, and speed.
Electronic Panels — Allows you to set the dosing time of two buttons from 1-99 seconds for single and double shots.
Stepless Grind Collar — Gives you complete control over your grind size, empowering you to find that perfect setting.
Portafilter Holder — Holds your portafilter while the coffee’s grinding..
