Sette 270wi Grind by Weight Grinder
  • Crema_Lad
    commented on 's reply
    Have PM’d you
  • crunchyfruit
    Thank you
  • Crema_Lad
    Sorry been away away, Will PM to posts and confirm if a sale reached.
  • crunchyfruit
    Also interested if this hasn't gone yet and can pickup within an hour
  • jettmyrmidon
    Hi hi, I would like to purchase this machine if it is still available. Best. j
  • Juwu
    Sent a pm!
  • Crema_Lad
    Hi All, price drop to $400 + postage. If no bites may consider keeping as 2nd grinder (pending bench space approval ?)
  • Crema_Lad
    Originally posted by DumplingCoffee View Post
    How much for shipping to Brisbane?
    Hi, standard poatage would be @ $20 to Brisbane.
  • DumplingCoffee
  • Crema_Lad
    started a topic For Sale Sette 270wi Grind by Weight Grinder
    Finally letting go of my beloved Sette 270wi (grief by weight) grinder. Purchased 2019 and used for 2 years, making 2-3 coffees daily. Gears were replaced under warranty but due delay in securing parts I used as an excuse (like we need one?!) to upgrade. Once gears replaced used rarely but confirmed to be fully operational. Has sat dormant dormant (but fully cleaned) for a couple of years as too hard to worry about selling during Covid, but now ready for a new home!
    Comes with Baratza drop down porta filter accessory (RRP $60) which I find reduces mess from grinds. It is shown attached in photos but easily removed.
    Selling for $450. Preferably pickup - can arrange shipping and quote will be provided on request. I no longer have original box but will ensure it is packaged suitably.
    Full Details:
    Porta Filter accessory:
    This accessory is designed for use on the Sette 270 and 270Wi when grinding larger quantities of coffee (say 20-23+ grams) into portafilters, by virtue of providing greater vertical distance between the discharge chute and the portafilter basket. The Sette grinds at very high speed, this accessory will help eliminate backup into the chute, with the potential to clog the grinder.
    Sette 270wi
    The second generation grind by weight model is a result of a great colab between Baratza and our good friends at Acaia. With the revolutionary ability to grind by weight directly into your portafilter (or grounds bin for you filter brewers out there). The big brother of the range, the 270Wi comes with Acaia designed Bluetooth technology to monitor, log and track grind sessions, weights and settings – as you can tell, this is a tool specifically made for home enthusiasts & baristas.
    • The "i" in 270Wi stands for intelligence. Since the 270W model, the grinder now quickly calculates and predicts the stop point when you change your grind setting, beans, or dose weight. This eliminates the need to adjust the offset.
    SPECIFICATIONS & FEATURES
    Speed to Grind: Espresso 3.5/sec Manual Brewing 5.5 g/sec Bean Hopper Capacity: 300-400g Grounds Bin Capacity: 160g Burrs: 40mm Steel by Etzinger Weight: 3.2kg Dimensions WxHxD: 13x40x24cm Power Rating: 230 V AC 280 Watts 50/60 Hz. 1.2 Amps Safety Listing: UL/CSA/CE/EK Designed & Engineered: Seattle, WA, USA​
    Located in Melbourne’s south-east.​
