FS Conti Monte Carlo & Mazzer SJ Electronic
This has been sold. Thanks so much for looking and for all the inquiries! Forum moderators: please mark as SOLD. Thank you!
- Likes 3
It’s a very well built machine. Made in Italy. The piping and wiring is very well laid out and service is very easy. I have photos of the internals if interested. I’ll send you a PM.
Hi Leverman, this looks like a great machine that has many of the features of far more expensive machines. I am unfamiliar with the Conti brand and can’t seem to find any reviews/info on the net from someone that’s not trying to sell the machine. I am interested in setting up a coffee cart with this sort of set up. What is the build quality like?
thanks for your time.
Rob
Up for sale is my beloved portable coffee set up:
Conti Monte Carlo MC 2G
Mazzer Super Jolly Electronic
I got this for temporary use for students in class I was teaching. All equipment is in excellent condition and in full working order with no issues. I was going to keep it for personal use after the class now but need to sell to pay off some bills. ☹️
The Conti Monte Carlo has a 2020 manufacture date and is the MC 2G model. This is a 3 boiler machine (one 10 L steam boiler and 2 independent brew boilers). Each is independently PID and SSD controlled. (6500W at max power setting). However, the reason I got this model was because you can adjust the power consumption on this machine through the touch pad interface. You can set it as low as 8 amp power draw! That’s where I currently have it set so I can run it off a standard household outlet and still run other appliances on the same circuit. You can set the power in several steps from 8 Amps for low usage up to 30 Amps for high usage. It also has an “Eco” feature which lets you drop back to “keep it warm” for overnight power saving. It has programmable soft pre infusion and ml volumetric dose control plus built in shot timers, and full barista work lights with an amazingly cool transparent rear panel with internal LED lights. ?
The Mazzer SJ electronic is almost new with under 400 shots ran through it.
Asking just $4,300.00 for everything.
If interested I can also consider selling the rolling cart it is on, and the bottled water system I’m using to run it (so you don’t need to plumb it in). If needed I can assist with transport and install if you need help (just cover my cost). Located in Denham Court NSW (Western Sydney).
