Would also swap for HG-1 Prime.
RRP $3,750, this behemoth has never let me down. Super grind quality, very quiet, next-to-no grounds retention! It's had minimal home use - no commercial quantities, at the most I used it for two coffees per day but since 2021 only been used once a month. I single-dosed but its worm drive feed system makes it ideal for batch grinding as well.
On purchase I installed the Mazzer Espresso burrs (replacing the stock Turkish burrs).
Includes both the smaller hopper pictured, and a larger hopper. Can also include the timber stand I made to hold my tumbler. If you wanted a tumbler I have a spare black one at $100.
Specs:
The Mazzer ZM Coffee Grinder is a one of a kind, revolutionary piece of coffee equipment. Constructed to grind mass amounts of coffee in short periods of time, this grinder would make the perfect addition to any roaster, cafe or deli. This grinder has 20 settings making it easy to get the perfect grind for the specific requirement & a fast grinding speed for those higher volume customers. Features and specifications: Flat steel burrs - 83mm, Bag clip and canister for grinding, Net weight: 35Kg 800 Watt/ 10 AMP Single Phase Power Supply 64.5 cm H x 43 cm D x 24 cm W.
