Coffee Knock Drawer Pro Cub PC2
  • SOLD Coffee Knock Drawer Pro Cub PC2
    A sleeker alternative to the traditional knock box, can fit right under your grinder, saving you precious counter space. Made with stainless steel and a handsome walnut wood handle, it will seamlessly integrate into any style of a small cafe or home kitchen.
    Minimalist design
    The drawer’s minimal footprint and matching design make it perfect for home kitchens, coffee popups, or small cafes. And it is created to be robust enough for your grinder to sit on top. After pulling your shot, open the drawer and discard the puck from your portafilter into the Pro Cub then close it again. The drawer has nylon runners that make it slide smoothly so you never have to struggle with it. It’s neat, tidy, and simple to use.
    Absorbs Noise
    Discarding the coffee puck is a noisy affair. The Coffee Knock Drawer Pro Cub has a triangular delta bar that absorbs noise better than ordinary bars in traditional knock boxes. Underneath the drawer, the corners also have rubber feet in place to further absorb the impact and protect the surface of your kitchen counter or workbench.
    Made with stainless steel and walnut wood, the Coffee Knock Drawer Pro Cub is built to withstand the daily grind of a small operations cafe. The delta bar within the drawer also adds to its durability by absorbing not only the noise but the impact as well. Coffee Knock Drawer Pro Cub Features
    Space-saving - The sleek form of this knock drawer makes it a great alternative to bulkier knock boxes.
    Noise-minimizing - Designed with a triangular delta bar that absorbs noise and impact.
    Sturdy - Made with stainless steel and walnut wood for superb durability.
    Rubber feet - The rubber feet underneath the drawer help further absorb impact and protect your counter’s surface.
    Top vents - The vents on top prevent condensation and bad odours from forming.
    Smooth drawers - Nylon runners are fitted into the drawer so you can open and close it with ease.
    Pick up from Belmore in Sydney or $15 postage.
    Forgot to add, only a few months old and has barely been used.
      I own the same and can recommend. Having owned an ecm branded one prior, the build quality on this is superb, a lot quieter, and built great too! GLWS
        PM sent. Thanks
          This is sold.
