!!SOLD!!: Fiorenzato F5 Grinder
  • askthecoffeeguy
    Re: !!SOLD!!: Fiorenzato F5 Grinder
    this machine has now sold congrats to jerome and thanks to all who expressed interest
  • askthecoffeeguy
    Re: FS: Fiorenzato F5 Grinder
    Originally posted by 70574D5C4B7A565F5F390 link=1257004512/3#3 date=1257165384
    Hi, since its only a few months old do you have the receipt, for warranty purpose should it be required?
    Ill have a look for you
    btw the advertised asking price is not negotiable so folks please dont ask for less Id rather keep it as a spare than give it away...
  • jerome
    pm sent! Thanks!
  • Coughy
  • askthecoffeeguy
    ok this is a stock image but my grinder does not differ from same as anyone willing to inspect it for themselves will soon discover!
  • askthecoffeeguy
    Ok She Who Must Be Obeyed says that it had to go do Im dropping the asking price to $500 which is cheap as chips for a machine of this calibre and build quality - ill endeavour to get some photos up in the next day or two - but my offer to view sill stands and you can take it for a test run as well - you try you like you like you buy!
    ;D
  • askthecoffeeguy
    started a topic !!SOLD!!: Fiorenzato F5 Grinder
    Bought this grinder new for my cafe buts its surplus to demand and it would have seen only a kg worth of use maximum - its in excellent working order, is only a couple of months old, and would be great for home use - my asking price is $595
    Specs are as follows:
    Features a modern designed heavy duty cast alloy body and 63mm grinding blades. Continuous micrometric grinding adjustment with steel dosimeter and dose counter. The fiorenzato is ideally suited for large commercial use.
    63mm Grinding Blades
    Power: 350W
    Motor RPM: 1350
    Net Weight: 14kg
    Gross Weight: 16kg
    Grinding Capacity: 8kg-10kg per hour
    Dose Counter: Yes
    Automatic Stop: Yes
    Height: 620mm
    Wdith: 250mm
    Depth: 400mm
    You are welcome to view this item and its listed as pick up only from Thornbury in Victoria
    ACg
