Re: FS: Bezzera BB105 Commercial coffee grinder - Doser
P.S. Forgot to mention that all wiring leading to the windings was recently replaced by an electric motor rewinder because some of the insulation had cracked on a wire, so the motor is in excellent condition. Massively over engineered as all Bezzeras are, huge shaft and should run for a long time still.
!!SOLD!!: Bezzera BB105 Commercial coffee grinder - Doser
Thanks for your query Matt. According to Auspost, given that it weighs between 13 and 14kg, and given the dimension assuming that I supply my own box, the postage estimate by regular post is $29. I would prefer local pickup, although I am going to the Gold Coast in early July if that helps?
Hi, am interseted will you post to Bundaberg QLD 4670 if so how much?
cHEERS mATT
Ive got an older Bezzera BB105 (confirmed by Jack from Barazi) that is just too big for my needs. Once worked in a coffee shop and is still going strong. Shes not very pretty but it will grind the coffee rapidly and powder fine. Jack has confirmed that all important parts are readily available and are in fact interchangable with the current BB03 and BB105.
I welcome your inspection (Belmont North NSW) and reckon it is still worth $100 given its awesome functionality. Conical burrs are slightly worn but will still grind too fine for my Boema if you wind it down below 3.
Tags: None
