Can anyone help? I want to take this post down for a while as we decided we may keep it as our plan has changed now.
I can't find where to edit the post, no option.
!!!WITHDRAWN!!! - FS: (SYD) North Coffee 500gm sample roaster
Hi Contraband - just still available. We were close to pulling it down since no one wanted and just keeping it as our sample roaster.Originally posted by ContrabandCoffee View PostHi Josh. Is the roaster still available?
Still haven't fully decided.
How serious are you? Do you live in Sydney?
Hi Josh. Is the roaster still available?Originally posted by yoshjosh1985 View Posthi all -
price dropped again to 3200 as still no takers.
This is a decent 30% drop from original price and it is only a year and half old.
hi all -
So had some interest but maybe priced too high.
Dropped to AUD3500 as maybe you want a bigger discount from a new one right
I know I would so price is dropped.
Any takers?
I got my bigger roaster lined up and ready to go.
I have a 500gram North Coffee Sample roaster. Gas powered model. TJ 066
It is a great roaster being used by many professionals in the USA and a growing following in Aus.
I want to swap it for the 1kg model due to increased output requirements. It goes for USD3500 plus all the worries of shipping and cost
We are selling for AUD3900 total - you will need to pick it up. We could possibly arrange delivery in Sydney.
It comes with 2 temp probes. One main BT probe. I wouldn't really use the ET probe but you can likely install it properly.
It comes with all Australian fittings including electricity and celcius.
NC-500 500g Coffee Roaster Parameters Roaster Dimensions: 40×19.5×24 in (1016×496×610mm) Roaster Weight: 107lb (48.6kg) Chaff Collector Dimension: 7×7×13.8 in(178×350.6mm) Chaff Collector Weight: n/a Net/Gross Weight: 242.5lb (110kg) Crate Dimension(One Crate): 46×29.5×26.8lb (1170×750×680mm) Drum Thickness: 0.2 in (4mm) Drum Diameter/Length: 5.9/6.4 in (150/163 mm) Drum Construction: 430 stainless steel, welded Cooling Tray Dimension: 10 in (254mm) Cooling Tray Stirring Arm Length: n/a Average Roasting Time: 15 minutes batch Production: 4.4lb/hr,35.3lb/day (2kg/h, 16kg/day) Roaster Voltage/Frequency: Single phase 220v,15 amp service 50-60Hz Step-up Transformer: 120v to 220v, 1000 watt Drum Motor 15w Exhaust Fan Motor: 50w Exhaust Fan Max. Airflow: 70m³/h Cooling Fan Motor: 38w Cooling Tray Stirring Motor: n/a Heating Mode: LPG Max. BTU: 10,000 Burner Control: Needle Valve Gas Connection: 1/4'' NPT Typ. Chaff Collector Exhaust Temp: 300F Recommended Temp Controller Limit: 455F (about 30 seconds into rolling second crack) Max. Gas Usage 0.4lb/hr (0.2kg/h)
If you would some pics or have a look PM me. I can't seem to add pics to this post.Tags: None
