Want to pass on this Scace thermofilter to another snobs. It's similar to Scace II (which costs a bomb!) but without the pressure measurement component - only measures temperature.
Can be used for measuring/calibrating your brew temperature. Suits any E61 machine and any other machine that takes commercial 58mm basket. Not recommended for manual/spring lever machines though as the flow rate is very different (as I had found out)
To use it, you need to use a bottomless portafilter with at least 60mm diameter clearance and a meter (could get one from ebay relatively cheaply). I was using my own meter for roasting and thus the meter won't be included
$200 pick up from Fitzroy or plus postage.
