Robusta/Longberry/Peru
  • Robusta/Longberry/Peru
    i made a blend of
    India Miadikeri Robusta roasted 2 weeks ago
    Ethiopian Harrar Longberry roasted 2 weeks ago
    Peru Ceja de Selva roasted 1 week ago
    in a ratio of one third each. I wasnt intending to make a blend with 33% robusta but after my cuban turned to ash i thought why not?
    There is a nice berry subtlelty in the mouth, with the smoothness that i find of the peru there too, however the robusta is very prominent. I now understand a little better what the description bright may mean, as it seems to be that kind of thing in the mouth, which i assume is the robusta.
    Also i assume the large % of robusta is what has caused me to feel like doing all the odd jobs around the house that have needed doing!
    Re: Robusta/Longberry/Peru
    ;D ;D ;D
      Exactly what instant coffee would do too cleaning the kitchen now wouldnt you like a rest darling Why? washing dog n watering garden woohoo Are you ok? just keep walking just keep walking just keep walking >Should have kept that Nescafe Blend 43 away from that woman...
        In general, robustas are not bright (well, I should say Im yet to come across one, even in the high-end monsooned and parchment) and my experiences have shown robustas tend to retard (balance, offset, smooth) brightness and acid in a blend.
        It could very well be that the robusta is providing such a pronounced flat base that the Peru and Harrar are really shining through. Sometimes that is a wonderful thing.
        To draw a similar example, some blending experiments Ive undertaken using high-spec beans and then matching with firstly a quality base and then separately a lower-grade base.
        To total amazement (a.k.a shock), the low-grade base (a dirtier or rougher cup) actually gave better results when compared side-by-side with a high-end base.
        This logic has continued to confound me and Ive repeated the tests many times over and with different bases. Statistically, the lower-spec base seems to compliment the showcase/highlight beans to a greater extent, giving a broader palate spectrum.
        The learning for me has been - sometimes you dont always need to load up a blend with superstars in the hope they all play together perfectly and expect that the end result to be the sum of its parts.
          Thanks ccc2 for your comments, it makes things a lot more interesting to say the least. i think what i need to do is try some robusta on its own and get an idea of how it tastes, and then i will try the blend again. The only problem is i really dont want to have the robusta in that kind of % again (i didnt have it again after that day-scared), but im sure once i try it on its own, i will have a better idea of the whole scenario.
