When blending coffee, do you blend before roasting or after roasting ?
Coffee Blending.
G'day mate...
Either. If the beans in the blend are going to use similar individual profiles, then pre-blending works out very well. On the other hand, if various beans in the blend require quite divergent profiles to get the best out of them, then post-blending is the ideal way to go...
Originally posted by phwoolf View PostWhen blending coffee, do you blend before roasting or after roasting ?
Many thanks guys. As I am new to the blending scene and am using a Behmor, initially, I will do my blending after roasting each bean separately. Once I have gained a lot more experience with various beans and their profiles I will try blending before roasting.
Coffee Blending is necessary for espresso since a single coffee origin will lack the complexity desired. It is important to remember that the advantage of espresso over other brewing methods is a result of the formation of the crema. Without the cream the espresso would be strong, thick coffee. The crema is an emulsified layer of tiny, smooth bubbles that trap aromatic compounds. This layer coats the tongue and these small bubbles break over time allowing espresso to be enjoyed long after it has been consumed. An aromatic coffee, therefore, is essential to a well-prepared espresso blend.
Originally posted by laura541 View PostCoffee Blending is necessary for espresso since a single coffee origin will lack the complexity desired. It is important to remember that the advantage of espresso over other brewing methods is a result of the formation of the crema. Without the cream the espresso would be strong, thick coffee. The crema is an emulsified layer of tiny, smooth bubbles that trap aromatic compounds. This layer coats the tongue and these small bubbles break over time allowing espresso to be enjoyed long after it has been consumed. An aromatic coffee, therefore, is essential to a well-prepared espresso blend.
Originally posted by Dimal View PostNot worth responding to the above thread Leroy...
It's just straight out plagiarised material pinched from a website, not even an attempt at attribution or any commentary by the poster...
Here...
[ATTACH=CONFIG]14280[/ATTACH]
And here...
[ATTACH=CONFIG]14281[/ATTACH]
Mal.but end up looking
Here...
And here...
Originally posted by LeroyC View PostI did wonder Mal, but I thought I'd respond and see what came back. Spambot? Troll? Maybe mods should just delete the post. Well spotted mate.
Java "Troll what?" phileToys! I must have new toys!!!
It sounds horrible.
