Hi Yall,
Whilst most beans Ive roasted seem to fall within a predictable "espresso grind-range window" some [eg Indian Tiger Mountain & Bali Gunung Agung] fall right outside and seem to require extremely fine grind settings.
I recently seperately roasted some ElSalvador San Emilio Farm and Bali Gunung Agnung, thinking a 50/50 mix might make a pretty good combination, but I dont think Ill be able to blend them due to the significant differences in their required grind settings.
If I grind the BGA on the appropriate setting for the SEF, Ill get a 5 sec pour
and conversely,
I could perform a backflush if I ground the ESM on a suitable setting for the BGA.
Setting the grinder midway between both settings will still choke on the ESM and gives a 15sec gusher for the BGA.
So I am yet to try blending them.
So what does one do/How can you make this work? .....at the moment Im drinking SOs.
and conversely,
