Sour tasting coffee after about 7-10 days from roa
  • Sour tasting coffee after about 7-10 days from roa
    Hi,
    I hope you can help? I have notice that after about 7-10 days from roasting the coffee has a sour taste but it disappears after about 15 days. The coffee beans are from Coffee Snobs Brown Beans. This has happened on all the beans the latest ones I have purchased are;
    Colombian Volcan Galeras
    Sulawesi Toraja
    It’s almost like I should leave them mature before using them; but it does not quite add up.
    I have checked the temperature, grind, extraction times etc..
    I even purchased some LavAzza beans from Woolworths for comparison. The results were as I expected; not sour but of course lack the flavor, body, aroma and crema of fresh beans.
    Not sure what else to say? I would be interested in your opinions.
    Re: Sour tasting coffee after about 7-10 days from
    Welcome "bwilks".... [smiley=thumbsup.gif]
    Have you tried brewing with a slightly higher brew water temperature? That is, by using a slightly shorter flush before locking in the PF and hitting the brew switch...
      Hi Mal,
      I have even tried leaving it on for a couple of hours and with no flush but I still get similar results. I also checked the temperature of the water coming from the group head but this seamed ok.
        Hmmm,
        Sorry then mate , not sure what else to suggest. Maybe it is a blend that needs a more extended resting period before you open the bag? If you grab another lot from Andy, try to leave it rest for a minimum of 10 days and see how you go. We all know how fresh Andys BrownBay beans are so maybe its just a matter of being a bit more patient :-?
          have you tried extending your roast time
            Hi Graham
            ROFL - These were roasted by Andy!
            bwilks, with respect, maybe what youre tasting isnt sour, just bright? I know with my own roasts that the beans can change substantially on a daily basis in the first week or so post roast, and often seem to almost miraculously settle with a longer rest period.
            Cheers!
              You may also need to let them "breathe" for a bit to let them stabilise. When you open a new bag, the beans character tends to be all over the place for a bit, before they settle.
                well thats one less variable
                  Thanks for all your comments they are always welcome.
                  I have considered that I may be misinterpreting the taste as I am quite new to this but I think I am on right track. I have used these links here to help develop my tasting abilities.  If you have any suggestions in developing/learning/improving for evaluating and tasting I would be most interested.
                  http://coffeesnobs.com.au/YaBB.pl?num=1218074243/8#8
                  http://www.wholelattelove.com/articles/images/coffee_tasting_flavor_wheel.jpg
                  http://www.atdcusa.com/flavor.html
                  http://www.roastmagazine.com/roasting101/cupping/cupping.html
                  http://www.roastmagazine.com/roasting101/cupping/cuppingform.pdf
                  I am thinking that the words; breathe, stabilize and mature are the likely fix. I am going to start logging the result on a daily basis it should be interesting over time.
                    Gday "bwilks",
                    Glad to see youre starting to sort it out mate; a very interesting (and enjoyable) journey this path towards knowledge of all things coffee.... The good thing is, it never ends
                    About improving ones potential for the development of a more discriminating palate, there is a great seminar coming up in Melbourne soon that deals with exactly the question you have asked. The inaugural seminar a few weeks ago was a great success and thoroughly enjoyed by all participants, so maybe it could be worth your while to consider attending? Anyway, heres a link to the details about this event...
                    http://coffeesnobs.com.au/YaBB.pl?num=1220319907
                      When I get this sort of thing happening (and it has just happened to me with some of that Mountain Top Bin 35) I have been able to finesse it a bit by:
                      . grinding the beans when I turn my coffee machine on (ie. an hour or so going off in the grinder is equivalent to at least a few days in the bag, methinks)
                      . upping the temperature as suggested above (this lot of Bin 35s seems to need a much coarser grind and a much higher temperature than usual beans)
                      . updosing and extracting slow, thick and short.
                      Anyway, that seems to have fixed things up to drinkable. Now as the days are going by (day 8 now) things are definitely on the improve.
                      And Ill try and do a better roast next time (I think I missed reaching second crack!)
                        Hi,
                        Update: I left the beans alone for a week and tried them aging and the sour taste has gone. The coffee taste great!
