PNG Kone Ka
  • PNG Kone Ka
    Have tried this today twice as long black and espresso, 3 days post roast
    Ill be honest I have an awful palate so cant go into specifics, its still a touch young, but very sweet as a shot or long black, very clean and short finish but a rather bold flavour at the same time
    All I could pick up was some citrus flavours (I can only ever pick up things like citrus, chocolate and such)
    Roasted 350g on 1lb, P4, C setting in the behmor, got to the first snaps of SC in cooling
    Will give it a couple more days and see how its going
    Re: PNG Kone Ka
    Im assuming this refers to the peaberry... totally agree with the sweetness it was lovely, a real suprise, and some earthier qualities too was expecting it would be a disaster as espresso but i would recommend it heartily
      Re: Peru Ceja de Selva Estate
      I just tried the PNG Kone Ka Estate from the last beanbay as a flat white it is very very nice with a lovely buttery mouth feel to it.. :P
      The roast was to the first snap of S/C  CS/C9..5 days post roast..
      Cheers Gra....
        Re: PNG Kone Ka
        I REALLY enjoyed this SO, but always struggle trying to describe in terms of acidity, body and flavour. Also took my roast to the first snaps of second crack. CS9ish. I would be interested in knowing how an experienced cupper would describe this one. Any takers....
          Re: PNG Kone Ka
          Roasted 500gr in corretto to CS10 left for seven days put through triple blind basket as an espresso you buety.Pour was heavy with thick crema and drank as a sweet chocalate with a hint of citrus.Pleasant after taste that lingered for quite a while.Very enjoyable and looking to drink the balance.
            Re: PNG Kone Ka
            May I make a correction to my previous post on Kone Ka.I meant a triple basket in a naked porta filler. Also add to taste grass or leather in after . Thank you for your patience.
              Re: PNG Kone Ka
              just did a batch of this one again tonight
              not sure if its happened before or not or just noticing it now, but first crack was barely audible, less so than second which I thought was odd, slightly shorter roast time, same batch size and about the same roast level (CS10ish)
              has anyone else noticed this is a quiet bean or is this perhaps a once off for me
                Re: PNG Kone Ka
                Yep, pretty quiet. I roasted a batch of it tonight in the Gene and I had to tell everyone to keep the noise down inside our house as it was hard to hear in the Gene. But once it got started it was obvious, but a rather quiet cracker  ;D
                  Re: PNG Kone Ka
                  Made a really good aeropress today at work and thought Id share. I found this bean quite enjoyable to taste and describe. Roasted by Coffeesnobs.
                  I found it to be quite zesty with hints of lemon/lemongrass and a tiny bit of sour grape. It had a very nice acidity but I found it didnt last too long. It has a very subtle finish which isnt overbearing, which had slight notes of toffee, that also didnt last all that long.
                  Id love to try this from an espresso, but I dont have one yet?
                    Re: PNG Kone Ka
                    Rightly so Cooba84, this has been one of my fav beans so far as an espresso. It found it quite well balanced as a single and good body and length. Will be on the lookout for more thats for sure.
                      Re: PNG Kone Ka
                      The secret to this Kona Ka, is that its actually a fantastic base for a blend. I like it a lot when blended with a Costa Rican Las Pavas, both roasted around the CS9 - 10 mark.
                        Re: PNG Kone Ka
                        @ausnadian - Ive actually got a fresh bag of Las Pavas which Im going to open up this week. I might even save some of the PNG beans I have left and try your blend.
                        I also thought Yirgecheffe would go well with the PNG as it has such a distinct flavour, the PNG would even it out.
                          Re: PNG Kone Ka
                          Lovely bean
Name:	Roast #63 PNG Kone Ka.jpg
                            Just started drinking Roast #63 PNG Kone Ka
                            Did a slow roast to first crack (1C) at time 12:57 at temp 204.4C.
                            Backed off the heat and HG height to pull at the start of 2C at time 23:56 temp 229.1degC.
                            From 5 days till now (7 days) just brilliant in the cup.
                            18g shot (30ml pour) as a latte just beautiful flavours.
                              Originally posted by sando View Post
                              [ATTACH=CONFIG]90[/ATTACH]
                              Hi Sando
                              Welcome!
                              These PNG beans are great :-) Glad its good in the cup!
                              Just wondering about your profile? The 12 mins to first looks great - but the 10-11mins from 1c to 2c is pretty long, and with that 20+ deg drop looks like the roast has stalled pretty significantly. From all I've read the aim is to climb right through the roast with no drop in temp, while still slowing towards the end…
                              It looks like you have a good gun setting for the rise to 1c. But maybe reduce the amount of HG drop at 1c? I only drop gun temp 50deg just before 1c (@ 195deg on the DMM), then another 50deg end of rolling 1c (210 deg on the DMM) which gives a steady 3-4deg per minute rise from 1c to drop point in about 6mins later.
                              Just a few thought :-)
                              Matt
