Results 1 to 5 of 5
Thread: Water Softeners
    Oct 2008
    58
    Water Softeners
    Has anyone tried using these or know if they are a viable option? mod edit- URL removed. *I will need to install a softener of some type and these look to be simple to fit and supposedly last forever. *Any comments or advice appreciated.
    14,665
    Re: Water Softeners
    Hi Ento,
    Bombora supplies <<<<<<<<<<< site sponsor will assist you great coffee specific water softening gear...
    2mcm
    Oct 2008
    58
    Re: Water Softeners
    Whoops, I inadvertantly directed this to a non sponser commercial site. I only wanted to clearly identify the product in question. This is the so called "MAIC" water softening system (MAgnetises, Ionises, Catalyzes). Anyone used one or can advise whether these are a viable option? It seems a bit questionable as the calcium is not removed, but instead "suspended" in the water by the process, so supposedly it will not calcify in the machine, but merely pass through the system. Any comments appreciated.
    Senior Member speleomike's Avatar
    Nov 2005
    923
    Re: Water Softeners
    Hi
    This is my personal opinion. Background: Science (PhD) and Process Engineering. Quoting from a few websites http://www.imexserve.it/water-softener-pr-28.html,
    http://www.empiresteam.co.nz/products/other-products/water-softeners/
    The MAIC technology works in 3 stages:
    * MAGNETIZATION: The energy generated by the permanent magnets
    causes molecular decomposition.
    Personal opinion: CRAP
    * IONIZATION: The magnets are positioned in alternate polarity to break
    up the bicarbonate molecules, thus reducing them in shape and volume.
    * CATALYZATION: The catalytic induction fixes this transformation and
    keeps it more stable and durable even in presence of high temperatures
    or high water hardness.
    The effect of this process through the MAIC technology is that a new
    crystal is formed, the Aragonite, which stays suspended in the water
    and is exhausted by the simple water flow.
    I dont have a phase diagram handy to look at to see the stability of the
    aragonite form of CaCO3 compared to the calcite form at room temp and coffee boiler temp/pressure but I doubt the temp/pressure range will have any effect. The addition of salts such as sulphate, magnesium ions do have an effect on the crystal form of scale deposited in kettles (it can often be in the form of aragonite) but magnets have no effect.
    My advice is to steer clear of products that make claims such as these.
    Mike
    Oct 2008
    58
    Re: Water Softeners
    Thanks Mike, I thought it sounded a bit like "magic petrol saving crystal" technology, but always good to find out what others have experienced or deduced.
  1. Bottled Water - Perth Area, very hard water.
    By dskilton in forum Brewing Equipment (non-machine specific)
    Last Post: 15th May 2012, 01:24 PM
  2. Water treatment - Scale inhibitor Vs. water softner
    By prloring in forum General Coffee Related...
    Last Post: 11th February 2012, 10:04 AM
  3. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 01:53 AM
  4. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 10:43 PM
  5. Water softeners
    By DAF in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th February 2008, 11:29 PM
