Results 1 to 4 of 4
Thread: Volume of 60-70kg coffee bag?
    May 2008
    441
    Weve been making enquiries about buying whole bags of coffee. Not sure if its going to work out to be viable for us or not at this stage... and not sure if we can risk buying a bag of coffee that Andy hasnt pre-tested for us!
    Anyway, for getting a freight quote, we need to know the volume of a bag of coffee. Can anyone help me out? I suppose what wed need is the measurements of the box one would pack a bag into. Estimates for 30kg and 60-70kg bags would be valuable if anyone has them.
    Stuart.
    Feb 2009
    82 Abbotsford Road, Bowen Hills, QLD, 4006
    179
    Re: Volume of 60-70kg coffee bag?
    Hi Stuart...
    Hope this helps...... a 60kg bag dimension is approx as follows when it is full...
    1metre high....... 50cm deep.........70cm wide...... i would not reccomend putting a 60kg or 70kg bag into a box...... the bag is easier to freight on its own...
    (please note that 70kg bag is not much different to 60kg bag)
    As for a 30kg bag.... approx....... 60cm high........30cm deep.....40cm wide...
    hope this helps....
    May 2008
    441
    Thanks Phillip!
    I wasnt too far off with my estimations... ;)
    Stuart.
    Feb 2009
    North Rothbury, NSW
    1,104
    So a 60kg bag of coffee cubes up to around 87.5kg for freight purposes.......
    interesting
    ....using the fairly standard 250kg cubic conversion :D
  1. Maximum freshness for low volume consumption.
    By ezralimm in forum General Coffee Related...
    Last Post: 4th April 2010, 12:44 PM
  2. Shot Volume Question
    By oliphant77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th March 2009, 10:50 PM
  3. shot volume??
    By Dave_D in forum General Coffee Related...
    Last Post: 25th February 2008, 10:58 PM
  4. Bitter coffee - Grind or volume?
    By soferfam in forum Grinders
    Last Post: 8th January 2007, 02:25 PM
  5. Heat Gun Volume Question
    By Robster in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 24th November 2005, 09:25 AM
