Results 1 to 10 of 10
Thread: Newbie: please help me with directions.. I am lost
    May 2009
    169
    I have been reading the forum for the past month, this is my first post.. I am looking for some advice.
    For the last five years, I have been using my cheap Breville Steam/pressure machine. Will I benefit from changing to a machine that has a thermoblock? what are your thoughts on a Breville 800?
    I have a grinder, it is a conical burr HAND GRINDER! Yes, very long time between brews. I have only recently stopped buying supermarket ground bricks, to replace it with supermarket beans. Guess what, not much difference. I have more recently bought a 250gm packet of beans from a cafe that roasts. Wow, amazing difference.
    I have a tamp - it wasnt so long ago that I couldnt understand why my brews were like plunger mud.
    I am interested in roasting my own beans using a popper.
    So, where would you go if you were in my shoes? I am considering buying a Breville 800ES, plus a breville grinder BCG450. Is this a wise step up? Does it have pressurised baskets, and if so, what is the non pressurised basket to buy and where?
    To make my own beans,from what I have read, I need a popper from Kmart, some green beans, and then roast them listening for first and second crack - really that simple?
    I have noticed that my puck is sometimes soggy, and it seems to be when I use supermarket ground coffee. Is that about right, or is there something I am not doing correctly?
    My preference is for espresso shots, but the occassional milk coffee
    Thanks for the great forum!
    James.
    Nelson Bay.
    10,496
    Re: Newbie: please help me with directions.. I am lost
    James, welcome to Coffee Snobs (your salvation from bad/mediocre coffee).
    Youll get a lot more replies soon so let me briefly answer a few of your questions.
    I dont know the Breville 800 so will leave comments to others to compare to a thermoblock unit.
    "Amazing difference" - yes - never return to the dark side.
    800ES - others will comment.
    BG450 - NO! - Sunbeam EM450 is a minimum.
    Is roasting with a popper that simple? - Yes!
    Soggy pucks - probably the fault of the stale supermarket coffee and possibly pressurised baskets in your Breville.
    Enjoy the journey.
    Apr 2008
    Brisbane
    5,113
    Hey James hows Nelson Bay this time of year
    I have visited there several times
    What is you budget because if you can increase it a bit you can get a machine that is more reliable and makes better coffee
    Search out the Nemox Dell opera (machine grinder combo) for around $799
    You can also purchase them as separate units
    May 2008
    4,096
    I think if you are starting down the road of beinga Coffee Snob the Breville will soon prove to be less than adequate. The best thing to do is hang on to your current machine, buy a good grinder and then save pennies towards a decent machine. Spend some time at a sponsor that sells machines to get some idea what you want. Sibonis and JetBlack are in the Northern Suburbs of Sydney.
    The soggy pucks sounds like it may be related to stale coffee but could also be because of not having enough grounds in your group handle (under-dosed) or poorly ground coffee or a limitation of your current machine or just technique.
    Dont buy the Breville grinder. My first grinder was a cheapie and I ended up with poor tasting coffee and soggy pucks. Consider that your first investment towards coffee nirvana.
    This is the advice Andy provides for the sub-$500 coffee machines:
    Entry level (sub $500) domestic appliances that you would expect to find in the kitchen section of whitegoods stores. You can get a pretty good coffee from machines in this category if you use fresh coffee and dose/tamp well.
    If you want a better machine for under $1K then try for a Rancilio Silvia or a Nemox or even a Gaggia Classic.
    May 2009
    169
    So the sunbeam EM450 at $150 rrp is a better choice compared to the Breville BCG450 at $199rrp?
    What makes the less expensive machine a better choice (please dont hurt me, I am a bleeder) ;-)
    How I arrived at the combo of Breville 800es machine plus BCG450 is I have found it for $250 as an unwanted xmas present. BUT, i am not going to let value dictate to me on this one.
    My current machine does not have a pressurised basket (pressurised means one pinhole at the base of the basket?). I think it was $69 5 or so years ago, has basically an on and off switch.
    I think the soggy puck may be from stale coffee fro my tests this morning. fresh ground coffee created a puck that slipped out of the basket and I could crack it in two, with creme in my cup. The supermarket brick created a puck that had to be washed out, because it was muck and there was no crema.
    Are there any machines on the market that have a very classic look to them? like with a pressure guage, and lots of shiney bits, and something noone else will be able to use but me, because its MINE MINE MINE !?!
    I am definately going to roast - done deal.
    question: will I get a better coffee from a new machine? and how much do I need to spend to get a better coffee? I dont care about timers, and blah blah blah. looking at the breville website, I say it is like the bar italia, which says it is 3.5bar pressure - thats bad right?
    With regards to budget, I expected to get away with a machine and grinder for $200. I thought a grinder cost 19.95, till I realised its more a spice smasher. so, I upped it to $400 and now it looks like I will probably be lucky to get a combo for double that.
    Thanks, James.
    Apr 2008
    Brisbane
    5,113
    Quote Originally Posted by 243D2C3624450 link=1241216760/4#4 date=1241225569
    Good for you its a step in the right direction
    Dont worry to much about - if the machine is new or second-hand
    You need to think - "will this machine be up to the task"
    If you are able to try and use these machines you mentioned then you have your taste buds to guide you
    If you dont like the coffee they make then dont buy them its pointless to buy something that will not satisfy you
    Its better to save up for something that will
    By the way a good quality grinder can make or break an espresso machine it is the most important part of you kit
    Dont skimp on the grinder
    A_M
    A_M is offline
    Mar 2006
    6,381
    AS per flynn_aus
    Here is another post of his that may also go some way to add to your facts..
    http://coffeesnobs.com.au/YaBB.pl?num=1224157582/42#42
    The whole post and the others inputs, need to be reviewed as well.
    Nov 2008
    164
    Hi James
    We bought a Breville-800 prior to discovering this site. *I really wish that I had found CoffeeSnobs prior to going shopping, as you have been lucky enough to do. *
    The Breville-800 is OK, but not great. *In retrospect I dont think it is very good value for money. *If I could do it again I would have bought the Breville Ikon, which gets good reviews here. *Or even better, tried to increase my budget a little and looked at the CoffeeSnobs "Hardware for Sale" area.
    This afternoon we are dropping the Breville off to be fixed (still under warranty) as it has stopped working. * So we are back to using the Atomic (not all bad 8-) ) and are frantically putting all our gold coins into a piggybank for the upgrade.
    Cheers - Carrie :)
    May 2009
    169
    after a few hints and tips here and on other threads, i think I have found where I am going. rancilio silvia and rocky grinder.
    I bought my popper today and my green beens are on the way.
    Now, to find someone that is looking to upgrade their silvia/rocky combo.. if you hear of anything, please let me know. I will kepp an eye on the FS section as well.
    10,496
    Quote Originally Posted by 6F76677D6F0E0 link=1241216760/4#4 date=1241225569
    Proven by use.
  1. Lost my steaming mojo...
    By pronto in forum Milk Froth and Bubbles
    Last Post: 1st January 2012, 09:38 AM
  2. Silvia lost steaming pressure!
    By mattydv in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th September 2011, 03:49 PM
  3. Lost Collet from Hario Skerton
    By psncreative in forum Grinders
    Last Post: 5th March 2011, 02:52 PM
  4. Ive lost my thwack!
    By GregJW in forum Grinders
    Last Post: 9th March 2009, 09:35 PM
