Results 1 to 2 of 2
Thread: Weird White o-ring from AntiCalc in EM6910
    Feb 2009
    239
    Hi Guys
    I took the anti-calc filter out of tank while I gave it a clean and now have this little white o-ring type washer. I couldnt figure out where it went back in, called Sunbeam and they tell me it goes over the collar that feeds into the back of the machine (but that one is still there...
    so I dont actually know where this one goes...
    it is about 2 mm in thickness and about 10mm in diamter, any ideas?
    Cheers Melbuurn
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Weird White o-ring from AntiCalc in EM6910
    Quote Originally Posted by 5D555C524545425E300 link=1241270242/0#0 date=1241270242
    Hi Guys
    I took the anti-calc filter out of tank while I gave it a clean and now have this little white o-ring type washer. *I couldnt figure out where it went back in, called Sunbeam and they tell me it goes over the collar that feeds into the back of the machine (but that one is still there...
    Cheers Melbuurn
    Comes down to What was said Vs what was Intended Vs what was heard..
    Inside the water tank.. there is a little spigot that the Anti Calk filter fits on to..
    That is where that small Si o-ring goes ON to..
    The filter Spigot has a taper and when clicked into place the Taper and the O-ring match up to form a seal..
    Trust this helps... 8-)
    CS Sunbeam support staff.. Donations to teh FC fund always welcome... ;)
  1. Sunbeam EM6910 Suddenly Gone Weird With Milk
    By hamo in forum Milk Froth and Bubbles
    Last Post: 1st February 2019, 06:14 PM
  2. EM6910 Weird group seal behaviour
    By acoggins in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th July 2009, 05:50 PM
  3. New 6910 AntiCalc Filter
    By FJP in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th November 2008, 11:46 AM
