Results 1 to 8 of 8
Thread: Pour times for a double basket
    Nov 2005
    52
    Im a bit confused about pour times with a double basket. If I am doing 2 cups, it should be 25-30 seconds right? or should it be doubled to 50-60 seconds as I am filling 2 cups? And if the former, then a single shot in a single glass with the double basket should come through in about 15 seconds?
    Dec 2004
    Earth!
    15,924
    Re: Pour times for a double basket
    The pour time should measure the 25 seconds reguardless of whether its a single or double shot.
    Java "Uuummm...oozing brown gold" phile
    Feb 2005
    441
    yeah, at first it didnt make sense to me either (double the water, double the amount of ground coffee, but the same extraction time???).
    But when you taste a double shot that has taken 50-60 seconds to extract ... it makes sense!
    Nov 2005
    229
    Well, it does *sorta* make sense. Its a ratio that produces a value. Not that I have it right yet of course :)
    Grant
    Dec 2004
    Earth!
    15,924
    While the double basket holds twice the amount of coffee as a single, it also has twice as many holes in it for the espresso to pass through so a pull will take the same amount of time in both of them.
    Also keep in mind that the 25 seconds is just a general rule and should be adjusted according to your equipment, beans, and tastes. :)
    Java "Loves the double" phile
    Nov 2005
    52
    Ok, thats the way Ive been doing it. It just made me think this morning when I was just doing a single shot for myself, and so I only used the first 15 seconds or so of the coffee. In that situation, do you think its better to use the first 30 ml like I did, or pour into 2 cups, get the full 25 sec pour and discard the extra coffee. It uses no more / less coffee, just creates a bit of extra washing up :)
    Nov 2005
    229
    Read a quote yesterday - I think it may have been on here.
    "Taste is the only morality". Try both methods and then drink whatever tastes best to you.
    Grant
    Feb 2005
    2,968
    Occasionally I deliberately overload the double basket, then do a very leisurely 60 ml extraction which take 40 or so seconds. The coffee emerges as a very thin trickle, but the crema is dark and tastes superb.
  1. Replies: 6
    Last Post: 25th December 2012, 11:02 AM
  2. Tips for separating milk for a double-pour....
    By yojabbajabba in forum Milk Froth and Bubbles
    Last Post: 14th August 2012, 07:49 AM
  3. Please explain pour times
    By ddthiel in forum General Coffee Related...
    Last Post: 13th February 2012, 10:19 PM
  4. Double Shot Pour Brugnetti Simona
    By Ranga in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 17th September 2010, 09:13 AM
  5. EM6910 Single Pour & Double Pour Cutoff Problem
    By Coffee2Di4 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd October 2008, 06:49 AM
