Results 1 to 6 of 6
Thread: How can i avoid early blonding with fresh coffee?
    Feb 2009
    73
    Hey guys,
    I love fresh coffee, but being able to give the customer day in day out, a consistently good coffee is a challenge. I get coffee delivered fresh twice a week and while the ristrettos are tasting divine the espresso blondes and loses body very quickly (around the 17ml mark).
    I am using a La San Marco 85-E series paired with a Mazzer Major.
    The baskets are only 53mm (18g doubles) in diameter and thus requires me to down dose and grind finer. Something i am not usually used to.
    I have tried adjusting grinds and tamp pressures, but with no real consistent change.
    So, if anyone has any tips on how i could approach this problem, or if you have similar troubles I would love to hear from you.
    Ben
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: How can i avoid early blonding with fresh coffee?
    Quote Originally Posted by 4F63706C637171020 link=1248170941/0#0 date=1248170941
    Ok... That implies good beans... But;
    1: Do you know the roast date ?
    2: Did this just start to happen ?
    Feb 2009
    73
    Usually, we get the beans about 3-4 days after roasting. It has been happening since i have been using this setup and coffee.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 0E22312D223030430 link=1248170941/2#2 date=1248171885
    So when did you change the set up ?
    What was involved..
    1: You state USUALLY.... 3-4 post roast.. How do you know ?????
    2: You state this set up and coffee ? Does this mean you changed coffe ????
    Does this errrrr mean beans / bean supplier as well ?
    As your well aware there are many things at play and myself and others can not really comment or provide advice when we only have a little information and even that has assumptions involved.
    As GW would say; we need Intelligence and that can only be derived from good information..
    Sorry to sound a pain... But just like a home system or even a low end commercial machine...
    True blonding (watery) is usually only down to a few things and beans would be one of the biggest causes... Next to Grind and Tamp...
    There is a long topic on blonding and some interesting reading to be had for all.
    http://www.home-barista.com/espresso-guide-skills.html Thanks Mal
    http://coffeesnobs.com.au/YaBB.pl?num=1242338990/6#6 And again
    http://coffeesnobs.com.au/YaBB.pl?num=1222855075/6#6
    Oct 2007
    792
    you prob have already but..lock in your handle and before pulling a shot, check out the shower indent. you could be mashing your puck which could lead to channelling...
    aaron
    Feb 2009
    73
    Thanks AM,
    I am new to this cafe and so the setup is new to me. The roast date is on each bag.
    Cheers for the links, ill check them out :)
    Aaron, ill check about that mashing - good tip.
  1. Early Blonding and short exit time
    By hellofellow in forum General Coffee Related...
    Last Post: 19th January 2013, 11:16 PM
  2. Early blonding
    By det in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 16th May 2011, 04:25 PM
  3. Good crema and pour rate, but blonding early
    By Darkfalz in forum General Coffee Related...
    Last Post: 13th May 2011, 03:31 PM
