Results 1 to 3 of 3
Thread: Draining HX machine boiler
    Jun 2008
    251
    I am heading overseas on Tuesday for 3.5 months and my machine will not be used until I return. Is it a good idea to drain the boiler before I leave or should I just give it a really good flush when I return?
    If I should drain the boiler, is it just a matter of bringing machine up to temperature, drain water from brew head, then drain whatever is left from hot water dispenser? Thanks.
    14,665
    Re: Draining HX machine boiler
    Quote Originally Posted by 1E292F3F34255C0 link=1252799275/0#0 date=1252799275
    .... is it just a matter of bringing machine up to temperature, drain water from brew head, then drain whatever is left from hot water dispenser? Thanks.
    Hi Buschy,
    I replied to your email, but it bounced back (seems to happen a bit with you *:-/). Do as you have suggested to drain the boiler and then give it a good flush on your return.
    Bon voyage!
    Jun 2008
    251
    Excellent thanks! :).
    Ill look into the email problem.
  1. EM6910 - Draining pumps/pipes
    By IJustKnowStuff in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th May 2013, 09:10 PM
  2. Rancilio S24/S27 not draining, what to do?
    By quickling in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 18th July 2011, 10:20 AM
  3. Replies: 5
    Last Post: 28th June 2011, 05:40 PM
  4. Draining Brasilia Gradisca
    By Monti in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 14th February 2008, 07:56 PM
  5. Help me choose a new single boiler machine...
    By mrmarky in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th November 2007, 07:58 AM
