Results 1 to 6 of 6
Thread: how to find a leak you cant see or hear? help!
    May 2008
    600
    I have an espresso machine where there are lots of fittings in a confined space. I cant see any leaks, or hear any leaks, but am getting condensation. I dont know how to approach fixing it besides randomly redoing each join. There is one that is a compression fitting, and the sleeve is a bit loose fitting when undone and suspect this could be leaking, but to change the sleeve means replacing the pipe as well which is a bit of work and I want to avoid if unnecessary. Does anyone know a good way to check for leaks so I could confirm for sure if this join is leaking or not? Anything you can apply or spray on that will show up leaks? or other ideas? Thanks!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: how to find a leak you cant see or hear? help!
    Quote Originally Posted by 5154585C545B04350 link=1256893436/0#0 date=1256893436
    I have an espresso machine where there are lots of fittings in a confined space. *I cant see any leaks, or hear any leaks, but am getting condensation. *I dont know how to approach fixing it besides randomly redoing each join. *There is one that is a compression fitting, and the sleeve is a bit loose fitting when undone and suspect this could be leaking, but to change the sleeve means replacing the pipe as well which is a bit of work and I want to avoid if unnecessary. *Does anyone know a good way to check for leaks so I could confirm for sure if this join is leaking or not? Anything you can apply or spray on that will show up leaks? *or other ideas? *Thanks! *
    Any gas fitter will tell you that in the old days you used a special fluid... *To day ya just use soapy water... *That is water with a high concentration of dishwashing fluid... *Then with a brush lightly smear it on teh fittings...
    Be careful... Do this with the power out...
    Then run and see where teh bubbles come from...
    OR use a strong food colouring and run and look for the colour seeping out.. *
    Opps... Could mean a major clean and descale to rid of any stains...
    May 2008
    600
    Quote Originally Posted by 7D525B594E715D525D5B59515952483C0 link=1256893436/1#1 date=1256900776
    Any gas fitter will tell you that in the old days you used a special fluid...To day ya just use soapy water...That is water with a high concentration of dishwashing fluid...Then with a brush lightly smear it on teh fittings...
    thanks - do you think this would work when hot? I only get a leak under pressure, and the fittings are really close to the boiler so very hot.
    maybe if I get desperate!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 5D585450585708390 link=1256893436/2#2 date=1256935338
    ngerManagement wrote on Yesterday at 22:06:
    thanks - do you think this would work when hot?I only get a leak under pressure, and the fittings are really close to the boiler so very hot.
    Can see some issues but if ya put enought on.. even if it dries out when hot ... once the steam / hot water hits it you may get enough of an indicator...
    May 2008
    600
    couldnt find a leak, but there is one somewhere, so I removed the most likely point. I had to cut out the pipe going to the pressurestat. Then began putting together a replacement pipe only to find my 6mm compression sleeve doesnt fit on my 6mm copper pipe - not even close!
    May 2008
    600
    well replaced my pipe with some other fittings and after 1hr running no condensation yet - HOORAY. Hopefully drinking coffee from it tomorrow - my peppina needs a rest after giving it a good workout in the last month or so!
    Thanks for your suggestions AM.
  1. Lets Hear it for the Boy!
    By Coffee2Di4 in forum General Coffee Related...
    Last Post: 5th April 2010, 09:49 PM
  2. Hear the difference?
    By Dennis in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 10th November 2007, 04:43 PM
  3. Have you hear of...?
    By MeccasMocha in forum SOLD
    Last Post: 13th October 2006, 02:55 PM
  4. Hear the Tiger roar
    By Nyg in forum Cup Tasting Room
    Last Post: 4th December 2005, 11:57 PM
  5. Didnt hear the crack
    By Stark in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 15th December 2004, 11:04 AM
