Results 1 to 4 of 4
Thread: Using a fridge water filter for a coffee machine??
    Aug 2009
    472
    Just wondering what people in the know think about using an inline water filter designed for a fridge (5micron) as opposed to using one designed for a coffee machine?? Are they the same thing?
    Apr 2008
    Brisbane
    5,115
    Re: Using a fridge water filter for a coffee machine??
    Quote Originally Posted by 6C4852424940210 link=1256986305/0#0 date=1256986305
    Should work if the correct filter is used
    Contact Bombora and they will be able to advice you
    Jul 2007
    2,288
    A five micron filter will remove most of the larger sediment and (probably) the chlorine, so it is sure better than nothing.
    Unfortunately, this means the dissolved minerals will (likely) be untouched, so the scaling remains the same, and the smaller sediment, between 1 and 5 microns in diameter, gets through.
    It all depends on your water. I prefer the system I have now, a 1 micron carbon filter and an ion-exchange softener, especially with the reticulated water here.
    Aug 2009
    472
    thanks for the advice :) i wont worry with a fridge filter then I had a laugh
  1. storing coffee in the fridge
    By tintub in forum Roasted Bean Storage
    Last Post: 23rd November 2011, 12:42 PM
  2. What is the best water filter to use for a coffee machine?
    By michaelwooldridge in forum General Coffee Related...
    Last Post: 5th April 2011, 07:56 PM
  3. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
