Results 1 to 2 of 2
Thread: Teflon
    Jun 2006
    754
    Teflon
    Hey,
    I have decided that Ill give my solis a good clean and a rebuild. The question is that are normal plumbing teflon tape adequate to be used on the boiler? Like when the steam valve attaches to the boiler. Not quite sure if the stuff can handle the heat and pressure or would I need locktite or some sort?
    Thanks,
    CK
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Teflon
    Quote Originally Posted by 1A363F3F3C3C0612303D590 link=1258117783/0#0 date=1258117783
    Hey,
    Thanks,
    CK
    There are different types of Teflon (PTFE) tape for Gas, water etc...
    White, Yellow and Pink.. Not sure of the heat properties for all but think the Pink or white should be fine..
    Continuous Operating Temperature Unit C 260
    Flammability Flash Point C 530
  1. Teflon Portafilters for LM??
    By Lizzie in forum Brewing Equipment (non-machine specific)
    Last Post: 1st January 2008, 04:31 PM
  2. Where to buy teflon tape in Syd?
    By Shannon in forum General Coffee Related...
    Last Post: 5th November 2007, 07:36 PM
  3. Rocky and the teflon tape mod
    By Bullitt in forum Grinders
    Last Post: 6th June 2006, 08:56 PM
