Results 1 to 5 of 5
Thread: What temperature should the water be in the cup?
    Jim
    Jim is offline
    Apr 2006
    8
    Hello all,
    Im trying to figure out from the water temperature in a cup what the temperature in the boiler is. Im using a Rancilio Silvia.
    Ive heated the cup and run hot water through the group head before testing. Im running the water directly into the cup, not through the handle.
    The water in the cup is 78 degrees. Does this sound about right or is the boiler too cold?
    Thanks,
    Jim.
    Jan 2008
    1,756
    Re: What temperature should the water be in the cup?
    Ya just cant tell using that method jim, way way way too many variables there, from boiler to group, through portafilter and into cup of unknown temperature.........at very least you need to measure it as it falls out of the showerscreen, as close as possible, this wont give you a perfect result, but it will be a hell of a lot closer to true brew temp.
    cheers/\/
    warren
    Mar 2008
    554
    try this method from my website:
    http://home.surewest.net/frcn/Coffee/HowToTempCheck.html
    Aug 2004
    2,312
    Notwithstanding the above replies,
    this sounds "fine".
    Depends on what part of the temperature curve you caught the machine when it flowed the water into the cup, plus a heap of other variables.
    That said I will repeat, it sounds fine ie, doesnt sound like there is anything wrong with the machine temperature or thermostat wise, if that is what you are attempting to check.
    Use it and enjoy!
    Regardz,
    Attilio
    very first CS site sponsor
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 556176607B4C507C75757676130 link=1259882981/3#3 date=1259889170
    this sounds "fine".
    Use it and enjoy!
    Regardz,
    Attilio
    Bloody sponsors.. ;D They actually post and I fully concur....
    As a VERY rough guide - If it was <65 or above 80-85 I would be worried..
    Some where in between... Then it depends on so many ifs and buts... However ya going to be in the ball park..
    If it tastes good then OK... In future refer back as a reference..
  1. Expobar water temperature
    By Fair_Oaks in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th January 2012, 11:57 PM
  2. Using hot water in water tank for improved temperature stability?
    By jsrenaud in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2011, 04:16 PM
  3. Boiler pressure as water temperature
    By Andy-Gadget in forum Brewing Equipment (non-machine specific)
    Last Post: 18th March 2010, 06:47 PM
  4. Water temperature in Brasilia Lady
    By jblaze in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 22nd April 2008, 10:40 AM
