Results 1 to 13 of 13
Thread: shower screen removal
    Dec 2009
    8
    Hi all Im new to CS and could not find where to post this so I hope this as a new topic is ok . Im sure its been discussed somewhere on here before but I cant find it.
    Anyhow,
    After digging out and old dusty Milano evd2 espresso machine I had in the garage I have discovered that I cant seem to get the shower screens off. ( this machine came from a cafe I bought and wasnt maintained)
    there is no screw just a ...what looks like a rivet holding the shower screen on .. this machine really needs a good overhall and I need to get started asap .. can someone help in explaining what I should do.
    I dont have a manual for it.
    cheers
    May 2008
    441
    Re: shower screen removal
    I have no experience with this machine - or any commercial machines - but if the showerscreen arrangement is anything like the VBM DS my housemate has, the whole thing is held in place by the rubber gasket. Once you get that out - which can be a huge effort, especially if its old and perished - the shower screen will essentially come out too.
    Youll more than likely need a new gasket because getting the old one out will damage it. the easiest way to remove it is to screw a screw into the rubber and pull on that. My housemates gasket came out in pieces, and that would only have been a year old or so.
    Hope that helps.
    Stuart.
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Quote Originally Posted by 393D3D392B520 link=1259997758/0#0 date=1259997758
    That sounds like a typical replacement screen that is held in place by the rubber group seal. Usually it can be levered down with a flat screwdriver, working your way around the group and using the group for purchase. However if the seal has hardened, you may need to chisel this out first - it will come away in pieces.
    Cheers!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 4F4B4B4F5D240 link=1259997758/0#0 date=1259997758
    Hi all Im new to *CS and could not find where to post this so I hope this as a new topic is ok . Im sure its been discussed somewhere on here before but I cant find it.
    Anyhow,
    there is no screw just a ...what looks like a rivet holding the shower screen on .. this machine really needs a good overhall and I need to get started asap *.. can someone help in explaining what I should do.
    cheers
    Where are you located ?
    KK told me years ago... Get a couple of long wood screws ... Any type but with a nice sharp point and a good thread..
    Screw them into the seal on opposite sides and then you can use any sort of tool to grasp the screw head and pull down.. With two you can do it slower and work on one side and then the other..
    Read more on it and other ways here..
    http://home.surewest.net/frcn/Coffee/HowToGasket.html
    Dec 2009
    8
    thanks Dennis
    I had a go at this but it seems like the screen dosnt want to move and the edge of the screen bent.. it feels like the rivet really need to come out first .. the screens will not rotate freely either, this might be because it is stuck to the seal.. oh man I dont know if I should just rip it out and reck the screen..
    help
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 34303034265F0 link=1259997758/4#4 date=1260002668
    thanks Dennis
    I had a go at this but it *seems like the screen dosnt want to move and the edge of the screen bent.. it feels like the rivet really need to come out first .. the screens will not rotate freely either, this might be because it is stuck to the seal.. oh man I dont know if I should just rip it out and reck the screen..
    help
    A rivet is telling you something... It is not ment to be moved / removed by teh opperator...
    Remove the seal first.
    In addition to the link and my advice above...
    The E61 units do not have a screw and sometimes a rivet..
    Thus here is a great how to as to removing teh shower screen.. Not it OLD... Remove the seal first.
    http://home.surewest.net/frcn/Coffee/HowToE61gasket.html
    Dec 2009
    8
    cool, the pic of the e61 is the same as the one I have .
    thanks
    Dec 2009
    8
    well that was what I needed .
    thanks for your help I managed to get them out .
    the seals are still quite flexable which is amazing
    now to get onto the rest of the machine
    thanks again
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 5357575341380 link=1259997758/7#7 date=1260006091
    thanks again
    We are here to help if we can... In many cases.. It has all been said and done before.. Ya just got to know where to look.
    Now where did a put my coffee.... Has any one seen my coffee... Bugger.. Google does not work on my place.. ;D
    Apr 2008
    Brisbane
    5,115
    Yep thats the way I remove the shower screen as in AMs link
    However I have never once put a dint on it
    I use the handle of a tea spoon or a chopstick
    Also note that the seal has on one (top) side a taper on the outside edge
    And the other (under) side has a sharp edge
    When replacing the tapered edge goes up and in first
    Easiest way to replace after removal is
    Join/fit together the screen & seal (tapered edge facing up)
    Place both in the group handle filter section
    Lock the group handle into place (as if you are locking it in when making coffee)
    Easy as drinking an espresso * ;D
    Dec 2009
    8
    thanks Kosmo good tip on the seal and its tapered edge
    that would have been something to over look
    cheers
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,122
    Quote Originally Posted by 51757C7C7F7F4551756977751A0 link=1259997758/9#9 date=1260014339
    Good tips KK, had the orientation of the seal figured but had not considered your method of replacing the screen/seal, will certainly give it a go. :)
    Jun 2009
    Moonta SA.
    7,122
    Quote Originally Posted by 6D424B495E614D424D4B49414942582C0 link=1259997758/5#5 date=1260003675
    thanks Dennis
    help
    A rivet is telling you something... *It is not ment to be moved / removed by teh opperator...
    Thus here is a great how to as to removing teh shower screen.. *Not it OLD... Remove the seal first.
    Good link AM, your a fountain of knowledge. :)
  1. NS MAC Digit Dispersion Screen removal
    By skydragondave in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th February 2013, 02:22 PM
  2. Koala vice versa shower screen removal
    By abaddonxi in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 7th August 2008, 05:46 PM
  3. Gaggia shower screen
    By JD in forum Brewing Equipment (non-machine specific)
    Last Post: 28th January 2008, 05:43 PM
  4. Expobar Leva shower screen removal
    By Thundergod in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th May 2007, 09:49 PM
